just got a hardtop need help
Hey i just got myself a oem hardtop for my s. if i install it will i still be able to use my soft top if when i remove the hard top or will i have to take out the soft top or what? also i think i need to buy brackets for it. it has something mounted in the top with handle looking things but i think i need to get brackets that will mount in the car?
You don't have to remove the soft top you just fold it down, and if your hardtop didn't come with the fitting brackets you'll need to buy some, luckily mine came with the brackets but I think they can be pretty expensive. Also behind the seats there's a black trim panel which has the brushes on them, you may need to cut a bit of this away to fit the hardtop, but you can get replacement trim which has this part already cut away so if you remove the hardtop you can put the others back on.
