K&N FIPK question
K&N FIPK question
I just received my new K&N intake and am going to install it tomorrow and was wondering but never read it. Is the improvement felt immediately?
On other cars I've owned I had to remove the ground wire to the battery to "reset the car" and ecu so that it could adapt to the mod. Mostly for intake and exhaust mod's
Are you supposed to do that with the S? more specifically a 2004 AP2?
thanks dawgs
thanks dawgs
I didn't feel much when I had this one my car. It was louder at WOT but I didn't feel any noticeable gains on the butt dyno.
Yes, you're suppose to disconnect the negative terminal to let the ECU relearn the new intake flow.
consensus is you should...really easy to do...just make sure you have your radio code handy cause it will ask you for it when you try to turn on the tunes...other than that go for it
Don't bother with resetting the ECU. It will only take a day for the ECU to adjust, and there's really no reason to think that the reset parameter are going to be more appropriate than the parameters it already has.
Originally Posted by smartidiot2122,Aug 7 2010, 10:49 PM
but what about the dyno graph's of adding 9 HP? this makes me sad
