Sponsored by: CARiD
led light conversion
Old Feb 23, 2009 | 03:53 PM
  #21
dopesilverstone's Avatar
Originally Posted by Izn Trbl,Feb 23 2009, 02:24 PM
You may find the tubes on ebay, or just about any online computer place such as xoxide.com.
To plug them in, really all I did was took a little piece of acrylic that I cut to be the same size as the wedge the 194 bulbs have. Then cut a two notches on one side, took the bare wires of the CCFL and bent them over the notches. From there, you just plug it into the socket.
It is nowhere as hard as it may sound. If you want, I can do it in 3 minutes, take pictures, and PM you.
Let me know.
yeah could u pm me....i would like someting to refrence, thanks
Old Feb 23, 2009 | 04:09 PM
  #22
Let me know.
so i found this seller on ebay its pretty in expensive, is this the correct light
http://cgi.ebay.com/NEW-LCD-SCREEN-MONITOR...%3A1%7C294%3A50
  #23
Spec_Ops2087's Avatar
Originally Posted by DBXFX,Feb 23 2009, 06:19 PM
I could see what you mean with a normal led array with a bunch of standard leds facing one way, but what about these led's?
http://www.v-leds.com/Shop/Control/Product...r_by/sell_price
They are supposed to be very bright. They arent those stanard led types either; it think these high-powered types are much better.
And also, i'd just like to throw in that i have a set of those cheapo 4 led 194/168 bulbs in red as my parking lights as well as my clear side markers. The previous owner put them in. I have to say, for a couple of bux at autozone, they are pretty bright. They are very easy to see at night and are definately brighter than the stock clear bulbs.
they look like these
They are definately more focused because they are just 4 forward pointing leds, but the plastic diffusers still light up completely.
just a thought.
I really want bright reverse lights though, so if you have any experience with them, let me know.
I've seen threads using those same LEDs, at night they are great but during the day time they are way to dim to be considered even remotely safe.
The only real way of doing LEDs is either OEM or making a custom LED board that fills the entire lens using correct LED light physics. So yes, it can be done but 99/100 times its half assed to say the least and dangerous.
Old Feb 23, 2009 | 04:15 PM
  #24
racecar fun's Avatar
can someone post pictures of reverse light led's please
Old Feb 23, 2009 | 04:26 PM
  #25
Izn Trbl's Avatar
Naw, don't get that. You can get these:
http://www.coolerguys.com/840556012009.html
You get two tubes, but one inverter.
I'll get a picture or two tomorrow, and send them over to you.
Old Feb 23, 2009 | 04:30 PM
  #26
smallville160's Avatar
so u get 2 for 6bucks? can u splice the 2 lines coming out and hook them straight up or do you have to run it through the inverter?
Old Feb 23, 2009 | 05:37 PM
  #27
Izn Trbl's Avatar
The CCFL will not light up unless you have it going such as this:
power -> inverter -> CCFL
I had some time before the woman go home from work, so I made an example of how I hooked it up.
1. A piece of plastic:
http://s26.photobucket.com/albums/c122/MOD...atelight002.jpg
2. Cut to size:
http://s26.photobucket.com/albums/c122/MOD...atelight003.jpg
3. Cut notches for wires:
http://s26.photobucket.com/albums/c122/MOD...atelight004.jpg
4. Fold wires over notches to simulate a light bulb:
http://s26.photobucket.com/albums/c122/MOD...atelight005.jpg
5. Plug into bulb socket:
http://s26.photobucket.com/albums/c122/MOD...atelight006.jpg
After (4), you may use epoxy or heat-shrink to hold everything in place. Then go onto (5). Zip-tie the tube above in your bumper, and zip-tie the inverter to the stock wire harness.
I have had this done for over 3 months, and at least 8 washes. Never a problem.
There are other ways of wiring them up. You may also use these:
http://gonzo777.home.insightbb.com/diy/sid...impterminal.jpg
Good luck with everything!
Old Feb 23, 2009 | 06:59 PM
  #28
thanks Izn Trbl.............
Old Mar 1, 2009 | 01:36 PM
  #29
DBXFX's Avatar
does anyone know how to make them brighter at night?
swb1
Jan 8, 2017 05:29 AM
PhreshEmpire
Jun 8, 2012 03:17 PM
wdtd
Jun 21, 2011 06:34 AM
watchdogd
Nov 3, 2010 12:23 PM
Moddiction
13
Aug 20, 2010 02:58 PM
