Sponsored by: CARiD
Looking for brake pad recommendations
Old Jan 5, 2020 | 12:27 PM
B serious's Avatar
Originally Posted by cenix
noodels you should at least have the sport pads then (309's). I think the street pads are basically to appease the masses who believe they drive aggressively for street commute driving. The sport pads can be used for daily use and work well for spirited (canyon/mountain) driving. I wouldn't recommend the sports for anything more than that though.
309 = "Sport" and "Street Performance" (former name).
309's are an organic, "high temp" pad. They don't come alive until you heat them up. They also need re-bedding from time to time. This is why a lot of people complain about the weak initial bite.
308 = "Street". Repackaged Centric Semi-Metallic
Since 308's are semi metallic, they will actually feel like performance pads. They are fine for low temp use (spirited street driving, autocross, etc).
Typically, if you want low temp bite with *decent* elevated temp performance, you'd buy a plain jane, consumer grade semi-metallic pad like the 308.
Old Jan 5, 2020 | 01:25 PM
879's Avatar
879
Yes I am referring to the 309. That's the first time I've heard of them needing to be re-bed. I will give that a shot when we get a nice day out.
Old Jan 5, 2020 | 03:58 PM
Bama Dave's Avatar
Carbotech AX-6 front and rear pads. Excellent cold bite and not a track pad.
Not a rotor friendly pad either. To seat the pad you will need to get the pads to fade and then your done.
Old Jan 11, 2020 | 05:42 AM
Slowcrash_101's Avatar
OEM pads in the rear. Spend the money up front. The fronts do 70% of the braking and 100% of the breaking(rotors).
Old Jan 12, 2020 | 09:34 AM
S2KHANG's Avatar
HP+ bites good for daily driving. Just way too dusty though.
Old Jan 14, 2020 | 01:41 PM
alSpeed2k's Avatar
Aren't Project Mu HC800+ also discontinued?
Old Jan 15, 2020 | 09:08 AM
879's Avatar
879
Not that I know of, from what I read it is the HC+ that was discontinued and replaced with the HC+800
Old Jan 16, 2020 | 05:00 AM
S2k19's Avatar
What pads produce the least amount of brake dust but are decent for regular driving ?
Thank you
Old Jan 16, 2020 | 05:05 AM
B serious's Avatar
Thank you
Factory (genuine Honda) AP1/Civic Si pads are probably as good as it gets for this application.
Old Jan 16, 2020 | 05:24 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Are’nt AP1pad,discontinued???
