Major tire ware
Im am dropped on Eibach springs and i am going through tires real bad the insides of the tires are being worn out so bad i tried just using an alignment but no help do i need a camber kit to be able to adjust it more and if so were can i get a good kit??
Originally Posted by JstnRyan,Jul 17 2008, 06:46 AM
Please learn to use punctuation.
What are your alignment settings?
the s2k has an oe adjustable camber adjustment bolts. if you already went to an alignment shop, i suggest going to a better place since the eibach lowering kit does not drop the car enough to have a need for an aftermarket camber kit.
Enough said.
Originally Posted by iam7head,Jul 17 2008, 01:04 PM
twenty buck betting the OP didn't invest in an alignment after he/she messed with the ride height
Get a alignment. Even if you say you got one, go get another, from the best shop you can find.
