Sponsored by: CARiD
Major tire ware
Old Jul 17, 2008 | 02:16 AM
kylemonster85's Avatar
Default Major tire ware
Im am dropped on Eibach springs and i am going through tires real bad the insides of the tires are being worn out so bad i tried just using an alignment but no help do i need a camber kit to be able to adjust it more and if so were can i get a good kit??
Old Jul 17, 2008 | 03:46 AM
JstnRyan's Avatar
Please learn to use punctuation.
What are your alignment settings?
Old Jul 17, 2008 | 05:40 AM
jshimer23's Avatar
I agree. Eibachs only drop the car about an inch so an alighment should be able to fix any Camber issues. I don't have any tire wear issues lowered on Eibachs....
Old Jul 17, 2008 | 06:39 AM
Sinji's Avatar
the s2k has an oe adjustable camber adjustment bolts. if you already went to an alignment shop, i suggest going to a better place since the eibach lowering kit does not drop the car enough to have a need for an aftermarket camber kit.
Old Jul 17, 2008 | 07:29 AM
@nthony's Avatar
Enough said.
Old Jul 17, 2008 | 12:14 PM
Code3S2k's Avatar
Also toe wears tires faster than camber. Make sure your toe is set to 00.
Old Jul 17, 2008 | 01:04 PM
iam7head's Avatar
twenty buck betting the OP didn't invest in an alignment after he/she messed with the ride height
Old Jul 17, 2008 | 01:26 PM
@nthony's Avatar
Get a alignment. Even if you say you got one, go get another, from the best shop you can find.
shift9k
Nov 5, 2014 04:06 AM
Popa
Oct 29, 2011 09:05 AM
rj2000
Nov 29, 2008 09:17 AM
AslanS2K
Sep 16, 2007 04:17 PM
Colombino
Oct 24, 2001 01:58 PM
