Sponsored by: CARiD
Missing screw
Old May 19, 2009 | 10:21 AM
dkms2k's Avatar
Default Missing screw
I just noticed the top plug and screw are missing from my driver side door pull. What size screw needs to go in there? It's a 2003 if it makes any difference.
Any help would be greatly appreciated.
Old May 19, 2009 | 12:03 PM
Bryan@BerkTechnology.com's Avatar
Former Sponsor
I would suggest taking it to the dealer, they will have the correct part and it shouldn't be to expensive
Old May 19, 2009 | 12:09 PM
s2kobsession's Avatar
you mean the handle on the inside of your door? or the piece of plastic that has the fuel door release come through it?
both have screw's and both have plastic/rubberish caps
you are best to go to dealership though.
Old May 19, 2009 | 01:00 PM
s2.Lazy's Avatar
http://www.hondapartscheap.com/southbay/jsp/home.jsp
they might have it there but not sure. you can check.
Old May 20, 2009 | 06:02 AM
dkms2k's Avatar
The door handle pull you use to close the door. From what I have been able to discern through searching and write ups on removing the door panels it's just a phillips head screw. I was hoping to find a picture so I could at least make an educated guess as to length, etc. and just find a suitable replacement.
I will check with the dealership. Thanks for all the replies.
Old May 20, 2009 | 07:00 AM
smallville160's Avatar
might also find it here www.collegehillshonda.com but i think your best bet is just going to a dealer most likely they use that screw on more then just the s2000 door handle and will have plenty
Old May 20, 2009 | 11:17 AM
AngryTurtle's Avatar
the bottom screw is the exact same as the top, just take it out and bring it to a hardware store. As for the plug youll have to get that from honda.
Henwhee
Jun 20, 2012 06:43 PM
fishyirl
Feb 16, 2009 12:41 PM
RL428
Dec 6, 2008 06:03 PM
WildS2K
Mar 10, 2008 07:07 PM
nearwater4me
Apr 5, 2007 04:37 PM
