How to remove door panels?
two screws in the handle, one on top and one on bottom. they are covered so just pry them off with a small flat head screwdriver. one screw behind the door handle. and lastly one small plastic one on the inner top area of door. from there just pry off gently with your hands beginning at the outer bottom of door...sorry for the lack of pics.
are you looking at this page?
http://users.rcn.com/dhintz/Michelle/Audio/audio.html
instructions are to the right of the picture of the door with panel removed.
Three screws: two in the handle, one behind the door pull handle (lever you use to open the door). The two in the handle have small covers on them, pop them off with a small flat blade. There's one plastic trim screw that needs to be popped out at the front of the door up by the mirror.
Once you've got all those out, there's two slots along the bottom of the door skin, get your hands in there and give a good tug, it'll pop out. Then slide the door skin up as it hangs at the top. Disconnect the door lock and power window connectors and you're good to go.
I just did this over the weekend to put in some component speakers. Piece of cake
