Sponsored by: CARiD
Modifry Redline Shift Beeper
Old Aug 5, 2009 | 06:34 PM
S2KPC's Avatar
Default Modifry Redline Shift Beeper
I just got mine in the mail and will try to install it this week ... I keep bouncing off the rev limiter when getting onto the highway. The S2K is so smooth on acceleration it's amazing.
For MY07 ... instructions give two options: behind passenger dash panel and next to the ECU behind driver foot well panel. Which is a better location - easier install?
If the driver side, understand that to take off the footwell panel, you have to take off the sill first ... right? Does that just pull up?
If the passenger panel, what's the best way to take that off ... worried about breaking those clips. Can you easily hit it from behind?
And, where should I put the beeper ... if I put it behind the panel will it be loud enough. Thought about putting it behind the seat ... but, will that be to loud?
I was planning on setting it at 8100 with 200 increments ... sound about right?
Old Aug 5, 2009 | 09:07 PM
chuhsi's Avatar
the beeper is loud. you'll scare passengers with it. mine's taped to a panel above the passenger foot. i can still hear it with my helmet.
just pull up hard on the door sills. they'll pop off from their clips.
Old Aug 6, 2009 | 04:19 AM
sparrow's Avatar
I put mine right behind the driver seat and couldn't imagine it anywhere else... Is it "loud", no. W/ my exhaust and going above 8k rpms its perfect.
Old Aug 6, 2009 | 09:58 AM
S2KPC's Avatar
Arggg ... I ordered the wiring kit with it. And, it isn't complete.
If you're wiring into the ECU, then you'll need to seperately purchase a
Old Aug 6, 2009 | 02:48 PM
S2KPC's Avatar
Drove 20 miles to get the missing parts. (Having to do that was what frustrated me earlier.)
Install was really easy ... took about 20 minutes to do everything ... and, pretty idiot proof.
The beeper was loud when I initially tested it. But, it's pretty muffled after being put behind the kick panel. Next time I'm in town, I'll pickup some wire and follow the advice of putting it behind the driver seat.
But, it works really well ... pretty pleased with the product.
Old Aug 6, 2009 | 07:21 PM
Harpoon's Avatar
200 rpm increments works well with NA. IIRC, 300 rpm increments is the recommendation for FI.
Old Aug 7, 2009 | 07:59 AM
centralcoastbuc's Avatar
Modifry's instructions show how to carefully remove that panel. Follow them, because it breaks easy.
Old Jun 27, 2019 | 06:25 PM
Redludesh's Avatar
With invidia exhaust you can barely hear it when it's attached to the box behind the "glove box" I would definately recommend a location closer to your ears if you have an aftermarket exhaust.
J33LUS
Apr 16, 2006 03:37 PM
blackfx35
Apr 26, 2005 04:10 PM
neil955
Feb 22, 2005 03:56 AM
s2000_19
Feb 18, 2005 03:47 PM
