Sponsored by: CARiD
Modify Dash
Old Feb 2, 2011 | 02:21 PM
phinancer's Avatar
Default Modify Dash
Hi All:
Back for some more advice from my favorite S2K Forum!
I have a 2003 S2K with a greddy turbo kit. My car was missing the passenger-side airbag, so I recently purchased one from a fellow S2Ki member. What I'd like to do is the following:
Modify the pass-side airbag cover to raise and lower depending on the position of the ignition key. I assume this could be accomplished by wiring linear actuators to the ignition harness.
Inside of the airbag compartment which is hollowed out, I'd like a compartment to be built to house gauges to monitor my turbo/engine: oil pressure, water temp, whatever...
If anyone knows of a talented stereo shop that could do such a project please let me know. I am located in OC/SD area in SoCal.
Thanks,
Old Feb 2, 2011 | 05:24 PM
Chow-bot's Avatar
so will the air bag still be functional? or are you taking it out?
Old Feb 2, 2011 | 05:28 PM
blobianco's Avatar
I think he means the car came without a airbag so instead of puttin that in he is going to put gauges in there!.... thats is a very good idea! curious to see how it come out!
Old Feb 2, 2011 | 05:59 PM
GizmoPhoto's Avatar
but he said he purchased an airbag from a fellow member. im confused.
Old Feb 2, 2011 | 07:04 PM
Chow-bot's Avatar
yes, that is why i am confused.
Old Feb 2, 2011 | 07:07 PM
CapoArgentino's Avatar
Banned
You can build an 'elevator' using metal parts from home depot. From there, a few electric actuators should do the trick. Gotta be designed from ground up though. Stereo shop I assume they would charge a pretty penny!
Old Feb 2, 2011 | 07:21 PM
phinancer's Avatar
Gents:
To clarify my point, I bought an airbag and airbag cover (attached) and plan to have the shop only utilize the cover for the project. Where the airbag normally goes, will be a fiberglass compartment, custom-built for my gauges.
Hope that makes sense...
Again, if anyone knows of a good shop in OC or SD, please advise.
Thanks!!
Old Feb 2, 2011 | 09:54 PM
phinancer's Avatar
No, the airbag itself will not be installed. Just the airbag cover.
Old Feb 2, 2011 | 09:55 PM
phinancer's Avatar
Thanks for the pointers, but this car is my most prized possession. I'd give my liver to ensure that everything was done with the utmost class and precision. A trip by me to Home Depot is not in my future...at least not for the S2k.
177ark
Mar 22, 2012 09:15 PM
phinancer
Dec 17, 2011 05:31 PM
phinancer
Nov 24, 2010 03:22 PM
LukeS2K4EVA
Oct 10, 2010 05:47 AM
dhess
Oct 22, 2002 08:35 PM
