Modify Dash
Hi All:
Back for some more advice from my favorite S2K Forum!
I have a 2003 S2K with a greddy turbo kit. My car was missing the passenger-side airbag, so I recently purchased one from a fellow S2Ki member. What I'd like to do is the following:
Modify the pass-side airbag cover to raise and lower depending on the position of the ignition key. I assume this could be accomplished by wiring linear actuators to the ignition harness.
Inside of the airbag compartment which is hollowed out, I'd like a compartment to be built to house gauges to monitor my turbo/engine: oil pressure, water temp, whatever...
If anyone knows of a talented stereo shop that could do such a project please let me know. I am located in OC/SD area in SoCal.
Thanks,
Thanks,
You can build an 'elevator' using metal parts from home depot. From there, a few electric actuators should do the trick. Gotta be designed from ground up though. Stereo shop I assume they would charge a pretty penny!
Gents:
To clarify my point, I bought an airbag and airbag cover (attached) and plan to have the shop only utilize the cover for the project. Where the airbag normally goes, will be a fiberglass compartment, custom-built for my gauges.
Hope that makes sense...
Again, if anyone knows of a good shop in OC or SD, please advise.
Thanks!!
Thanks!!
Originally Posted by Chow-bot,Feb 2 2011, 06:24 PM
so will the air bag still be functional? or are you taking it out?
177ark
Mar 22, 2012 09:15 PM
dhess
Oct 22, 2002 08:35 PM
