More Torque Pro parameters?
I have a BAFX OBD2 bluetooth scanner using Torque Pro on my android device that I've been using lately, and I'm wondering how I get additional readings such as oil temperature, AFR, etc.
Currently the app has those items grey'd out, and I guess doesn't get a reading for?
Can I get my stock S2K to get those values? Or are those open for other cars that actually have the sensors (I don't know if the S2K has them or not...)?
Thanks!
Thanks!
Hmm ok I'll have to look again but I'm pretty sure that wasn't an activated parameter for me in in the Torque settings. I even typed in all of the S2000 info for the vehicle profile and only a couple more options were enabled...
Is there something I'm missing? I purchased the full program for $5 on google play (android) and would purchase more packages if they were available but it looks like this is the full deal?
Doesn't look like our ECUs send any AFR data.. or perhaps rather, our O2 doesn't provide anything useful as mentioned above. I have the same setup, and all the possible AFR PIDs return no data.
PID
24
O2S1_WR_lambda(1):
Equivalence Ratio
Voltage
PID
34
O2S1_WR_lambda(1):
Equivalence Ratio
Current
PID
25
O2S2_WR_lambda(1):
Equivalence Ratio
Voltage
PID
35
O2S2_WR_lambda(1):
Equivalence Ratio
Current
PID
44
Command equivalence ratio
Only O2 data we get is raw O2 voltage
PID
Bank 1, Sensor 1:
Oxygen sensor voltage,
Short term fuel trim
PID
15
Bank 1, Sensor 2:
Unsure if we can use these to calculate AFR combined with any of the PIDs we do get data for, like fuel flow, fuel trim, manifold air pressure, timing.
PID
24
O2S1_WR_lambda(1):
Equivalence Ratio
Voltage
PID
34
O2S1_WR_lambda(1):
Equivalence Ratio
Current
PID
25
O2S2_WR_lambda(1):
Equivalence Ratio
Voltage
PID
35
O2S2_WR_lambda(1):
Equivalence Ratio
Current
PID
44
PID
Bank 1, Sensor 1:
PID
15
Bank 1, Sensor 2:
