Sponsored by: CARiD
NA?
Old May 28, 2008 | 07:51 PM
S2KKC's Avatar
Default NA?
Im going to go NA and had some questions. This might be a stupid question but does anyone have any info on the skunkk 2 camshafts and if they do anything. Just wondering what would be worth buying and if the car can still be quick. Im going from a comptech s/c car to NA with full exhaust and intake right now. So i want to know if the car i guess will still be a runner. Any info would help thanks.
Old May 28, 2008 | 07:56 PM
qbmurderer13's Avatar
Waste of money, theres no aftermarket camshaft that has proven any gains in this car. Honda has this engine dialed-in. Theres very few things outside of minor bolt-ons that will actually do anything. Save the money and get some FD gears.
Old May 28, 2008 | 08:00 PM
s.hasan546's Avatar
no cams available that actually make power and are available.
If you wanna go NA i suggest Headers, TP, exhaust, intake, Greddy EMU tuned, 4.44 (or any gear ratio you like). I kno im going to be doing the same but using the hondata tune for 06+ rather than the emu. All that should have you run pretty quick but probably not as quick as ur sc s. than try to shed some weight with some lightweight rims.
Old May 28, 2008 | 08:04 PM
S2KKC's Avatar
What gear ratio do you suggest?
Old May 28, 2008 | 08:17 PM
UpsFella's Avatar
would pulleys and lighter flywheel do it any justice ?
i also heard rumors about using one of the f22 cams on the f20.. not sure if it was the intake or exhaust though... im guessing intake.. is this any true..
srry for the thread jack..
Old May 28, 2008 | 08:18 PM
shotiable's Avatar
you have two choices, either 4.56 or 4.77. i dont have gears myself, but i heard lots of good things about 4.56, people say 4.77 is too much.
Old May 28, 2008 | 08:20 PM
BlownAP's Avatar
it might be worth a couple ponies to swap an F20c Intake camshaft on an F22c.
but you will see No gains from swaping f22 cams to your f20. intake or exhaust
Old May 28, 2008 | 08:21 PM
S2KKC's Avatar
Well right now i have the comptech supercharger which im getting rid of and i have invidia exhaust, berk test pipe, and am about to get a header. So i need gears and throttle body? Whats a good intake? Any thoughts on the ARC system?
Old May 28, 2008 | 08:34 PM
Do some research.
ARC intakes lose power.
Throttle body will not get you any power.
IMO best gear ratio is 4.44, decent low end grunt and still retaining the strong top end.
Old May 28, 2008 | 09:23 PM
S2KKC's Avatar
I was just watching videos on you tube of stock s2ks and ? Am i going to be very disappointed in my NA s2k. Again im just asking cause i dont know what to expect but it looked like they were taking awhile to even get to 100 i mean i can hit that easy on an on ramp. Or should i be good with all the mods we have talked about.
