Sponsored by: CARiD
NRG Engine Torque Damper Kit EDA-402SL
Old Jun 24, 2016 | 02:44 PM
horansky's Avatar
Default NRG Engine Torque Damper Kit EDA-402SL
Does anyone know how to install NRG Torque damper kit ? All i get in the box is whats on this website and by looking at little hole on mounting plate I'm completly lost! Also it doesnt have any bolt mounting to the engine which means i have to get one in the shop or whats the story ? Very dissapointed..
http://www.getnrgstore.com/index.php...roduct_id=1421
Thanks for help in advance
Old Jun 24, 2016 | 06:17 PM
FusionCola's Avatar
The big plate attaches to the passenger side strut tower. The other "L" shaped bracket will attach to the passenger side of the motor above the V-tec solenoid. I would assume the tiny hole needs to be drilled out to fit the bolt into the damper. This kit is for people not using a heat shield for the battery. If you want to retain the heat shield (I highly recommend it unless you've relocated the battery and other electrical components in that area) you need to buy the other kit designed to be used with a heat shield.
Old Jun 24, 2016 | 06:25 PM
AE_Racer's Avatar
Heres a pic installed https://www.s2ki.com/s2000/topic/400...per-for-s2000/
You will need a bolt to attach the bracket to the block and you will also need to remove the bracket for the fusebox closest to the motor.
Old Jun 24, 2016 | 06:28 PM
AE_Racer's Avatar
Hmm.. If thats the exact kit you have it appears it doesnt have the bend in the shock tower bracket like the one in my link? Odd.
jXxviii
May 12, 2019 10:54 PM
Moddiction
238
Feb 7, 2017 07:49 AM
mcopley
Aug 1, 2012 11:32 AM
efthimios
Jul 25, 2004 08:26 AM
