Sponsored by: CARiD
OEM hardtop installed with softtop removed
Old Aug 12, 2010 | 03:38 PM
Greg W's Avatar
Default OEM hardtop installed with softtop removed
Any suggestions on how to securely attach the hardtop's rear quick-release latch bracket with the softtop completely removed?
My new OEM hardtop fit perfectly when I had my softtop installed, even with my Hard Dog roll bar. I used the hardtop's supplied rear latch bracket that bolts onto the softtop frame's "anchor plate" next to the motors. However, when removing the softtop frame the "anchor plate", part of the softtop assembly, is also removed. That takes away a lot of support for the rear latch bracket. There now are only 2 bolts holding the rear hardtop latch bracket to the car (there were 4 bolt when the softtop anchor plate is installed). I know about Izzy's permanent brackets, but I like the quick detach capabilities of the OEM rear latch.
I couldn't find this addressed using search or in the Hardtop threads. How did others solve this?
Old Aug 12, 2010 | 04:43 PM
Spa_Ap1's Avatar
Use the CR's already detached soft top "anchor plate". Same piece as what's holding down the soft top only it doesn't have a soft top attached to it. Part #'s are 86121-S2A-A00 & 86171-S2A-A00 . I just recently installed these on my S after removing the soft top.
(Thanks to SlowS2k for pointing me in the right direction on those)
Old Aug 12, 2010 | 05:05 PM
siik_ap2's Avatar
wow nice ^^^ how much were those
Old Aug 12, 2010 | 05:08 PM
Spa_Ap1's Avatar
~$60 bux a side + shipping.
Old Aug 12, 2010 | 06:19 PM
Greg W's Avatar
Spa AP1, thanks. That's actually what I thought I'd see when I removed the softtop frame from my '05, but found the frame permanently attached to the anchor plate. Just ordered them from Magestic Honda, will be good to go in time for my Laguna Seca weekend next month. Mahalo!
Old Aug 12, 2010 | 06:22 PM
Spa_Ap1's Avatar
Yeah, I originally tried to seperate mine from the soft top as well. But it just wasn't going to happen without completely ruining the top.
Old Jun 21, 2013 | 11:24 PM
trunger's Avatar
Spa_Ap1 you saved me !!
Old Jun 22, 2013 | 11:22 AM
Driven's Avatar
You can also just use the forward two bolts for the brackets and bolt them to the chassis. You don't need all three.
Old Jun 22, 2013 | 12:19 PM
JUSTINTHECOASTIE's Avatar
For more weight savings, I removed the all the brackets and have the side catchers holding on by the two forward bolts on each side
Just saw driven beat me to it lol on my phone I had it pulled up to reply but just got around to entering the text lol
Old Jun 24, 2013 | 04:22 AM
Spa_Ap1's Avatar
Slows2k saved you, I was just passing along the info.
