Sponsored by: CARiD
One-touch soft top mod ?
Old Nov 27, 2009 | 11:07 AM
christoepurrr's Avatar
Default One-touch soft top mod ?
So I got curious today, while operating the top on my car. Has anyone done like a one-touch soft top mod similar to like a car with a sunroof in which you just touch the button once instead of holding the button down and it closes ?
Old Nov 28, 2009 | 05:58 AM
beatadrum's Avatar
I would love to see this done.
Old Nov 28, 2009 | 06:48 AM
s2k aok's Avatar
the more popular top down mod is wiring it so it doesn't require the parking brake to be set for operation...
Old Nov 28, 2009 | 08:39 AM
peterpablo's Avatar
that would be sweet now! being able to put the top up or down with out the parking brake on
Old Nov 28, 2009 | 02:13 PM
im sure it can be down using the same type of relays or whatever as those used in sunroofs and windows that have auto one touch feature ?
any electrical/wiring gurus willing to chime in ?
Old Nov 30, 2009 | 05:39 PM
should I be the guinea(sp?) pig for this ? lol doesn't seem too hard let's running a relay from those auto roll down/up windows ?
someone correct me if I'm wrong and make me feel dumb lol
Old Nov 30, 2009 | 06:14 PM
Sobe_Death's Avatar
http://www.google.com/products?rlz=1C1GGLS...ved=0CBkQrQQwAA
Old Nov 30, 2009 | 06:52 PM
TheMuffinMan's Avatar
Really would not be difficult, I'm sure the S has some type of switch to know when the top is fully retracted.
We do this stuff with PLC's, all you would need is a relay that latches itself on using itself. Then have the switch that detects if the top is all the way down or not open the connection.
For those that understand PLC's
R - NO Roof Switch
S - NC stop sensor (I would think we have one? or easily installed)
MOT contact - Relay contact that latches/bypasses the Roof switch
MOT - relay runs motor
*edited* to clean up diagram a bit
Old Nov 30, 2009 | 10:14 PM
lowrthnu2.2's Avatar
i did the opposite, pulled the speed sensor wire so i can put the top up while still moving but the e brake still needs to be pulled, just one click will do...its enough to engage the switch but not the actual brake
Old Dec 1, 2009 | 05:35 AM
AngryTurtle's Avatar
[IMG]http://img692.imageshack.us/img692/3489/captureqg.jpg[IMG]
R - NO Roof Switch
The only problem is that you will not be able to stop the top when it is going down. It is either open or close that's it. You could use the e-brake being off to stop the top but it is a ground switch. And just putting the e-brake down without having it connected to the relay will cause the top to go down as soon as the e-brake is back on.
