Sponsored by: CARiD
Piston question
Old Oct 5, 2012 | 06:26 AM
little_chicken's Avatar
Default Piston question
Rebuilding an engine, and by rebuilding I am pretty much starting from scratch. I have a good block and good crank. I plan on putting aftermarket rods in, and I would like to use aftermarket pistons WITHOUT sleeving the block. So that narrows it down to mahle, unless there is something new I have not heard of. Will someone help me find a part number for a set of pistons to keep me at the factory compression ratio. Btw, I have an ap1 block, crank, and head.
Old Oct 5, 2012 | 08:22 AM
Kyushin's Avatar
Banned
You would have to contact Mahle, not sure if they make OEM ratio pistons but maybe this link will help http://realstreetper...-f22c-2870.html
As for the block itself, make sure the FRM liner is round and perfectly mirror finished because if not, you will have trouble later on. I have heard a number of builders say that with some mileage, the cylinders can go out of round and only a very small few shops know how to hone these blocks properly and even then you have a very small margin to work with.
AP1 Mahle http://realstreetperformance.com/sto...f22c-2797.html
gj_magi
Nov 1, 2017 06:07 AM
THE BOM3
Apr 15, 2014 09:47 PM
omar_sanchez01
Oct 8, 2012 06:10 AM
Clark
Aug 26, 2012 12:19 PM
0piston
Jan 11, 2010 06:30 AM
