Sponsored by: CARiD
Putting on TP...
Old Oct 31, 2010 | 11:33 AM
JEEBS's Avatar
Default Putting on TP...
So Im replacing my OEM Cat w/ a Berk TP. Im replacing the gasket between the TP and exhaust but what about the one between the header and TP? Do I need to replace it or even need one?
Also is this something I can buy at my local auto store? As far as the donut gasket.
TIA
Old Oct 31, 2010 | 11:40 AM
JSWhaler's Avatar
From the header to the cat/ test pipe you should have a donut gasket. From the cat/ test pipe you should have a triangular (circle cut out) gasket. Both can be bought at any automotive store.
Old Oct 31, 2010 | 11:45 AM
JEEBS's Avatar
Are they universal parts?
Old Oct 31, 2010 | 11:55 AM
spook's Avatar
I don't have a gasket in between my tp and header.
Old Oct 31, 2010 | 11:57 AM
JSWhaler's Avatar
Yes, as long as you get the correct sizes, which I can't currently remember but you shouldn't have a problem searching for the sizes or just go to hardtopguy.com
Old Oct 31, 2010 | 12:32 PM
FISH22's Avatar
Najib, I'd recommend replacing the donut gasket. I've always done it when installing new exhaust manifolds or test pipes/CATs.
You can get them from Majestic Honda(hondaautomotiveparts.com) for a pretty good price. I've been able to get a good price on them through Hall Honda(Virginia Beach), and they get them within a day(special order).
You said you're replacing the house gasket(the one between the test pipe and exhaust)? I'm assuming the test pipe already came with a new one?
Old Oct 31, 2010 | 12:49 PM
whiteflash's Avatar
You should have a gasket there. It's going to mate inside the tp though (it surrounds the outter lip of the collector on the header). If you don't, I reckon you'd have a pretty nice exhaust leak...
Old Oct 31, 2010 | 12:52 PM
Voodoo_S2K's Avatar
Unless parts stores are different in CT, no way you can walk into a parts store and get either, especially the flat gasket.
Old Nov 1, 2010 | 06:40 AM
flyingtoaster's Avatar
My gaskets were leaking so I replaced them using several layers of heat tape and a razor blade. No more leaks.
Old Nov 1, 2010 | 09:25 AM
TougeS2k's Avatar
Ya you probably have a donut gasket between the header and TP, i'd be shocked if you managed without it. It doen't look like a flat, maluable pancake gasket like on the other side, its fat and round and looks like steel whool all pressed together.
