Questions about RCAs
Hey everyone,
I’ve tried doing some research on this topic but can’t come up with a definite answer. I’m looking dial in some camber up front, while correcting the suspension geometry since the car is lowered. Can I run offset front roll center adjusters only, or would it throw off the balance of the car? Does it only make sense to do both front and rear RCAs? Any help is appreciated, thanks!
RCA's will increase roll stiffness at that end. So...it would be similar to putting a stiffer spring up front.
You can do Hardrace or Megan offset joints. The RCA plate is optional. You can opt to run stock height with the camber offset OR run the extended RCA plate.
You need to address the tie rod angle if you're doing an RCA. You shouldn't just slap on RCA's. Its a tuning exercise. You have to run either rack spacers or extended tie rod ends so that the instant center stays the same.
If you do REAR RCA's to balance the car out, you need adjustable, extended end toe links for the same reason. You then need to MEASURE(!!!!!) and tune the bumpsteer.
Why are you doing any of this, however? If its just a street car...just leave it alone unless you want to learn to tune it all.
My plan is to just dial in some camber without making huge changes to the suspension. With the wheel and tire setup I’m running, I need some more camber F&R, but I don’t think I’ll be able to achieve the specs with stock components.
I drive the car spiritedly, possibly going to do some track days when I have everything sorted; my point is, I don’t want to worry about ruining my fenders.
Oh. Your better bet is using UCA's to correct the camber up front.
Offset lower joints move the bottom of the tire out.
Upper control arm methods move the top of the tire in. So they more easily clear fenders.
Megan or Hardrace make UCA's that look to be good quality and come with sphericals.
Or you can use offset UCA bushings or slotted upper ball joints in the stock arms. If you buy black-booted SPC joints, make sure you remove the boot, clean off the shit ass grease they come with, and replace it with PTFE or Polyurea grease. They should last after you do that.
The UCA method has caster availability advantages too.
The rear should have tons of camber adjustment with the stock stuff. In the truly odd case that you need more, you can always use a UCA method back there too.
If you buy rear RCA's, the rear lower joints are not offset. No option to do anything there for camber.
So definitely stick with a UCA method if you need something additional for the rear. You *shouldnt* need additional rear adjustment though.
Honestly, the more stock stuff you can keep...the better you'll be from a quality/durability/simplicity standpoint.
I’m trying to keep an OEM+ setup, so as you mentioned the closer to stock the better for me. I also previously read there is plenty adjustment for rear camber; if I remember correctly I’m around 2.6 degrees currently.
You don't need supporting parts to do the offset bushings or Megan/HR UCA's, as I believe they keep the same balljoint length as the stock ones.
I would do the adjustable arms, as plastic bushings have their own downsides.
My order of preference for UCA methods:
-Megan/HR UCA
-adj. joints
-Bushings
-Megan/HR UCA
-adj. joints
-Bushings
josserman
Jan 12, 2014 01:17 PM
