Sponsored by: CARiD
redline shift beeper issues!
Old Jan 19, 2010 | 10:43 AM
josh7owens's Avatar
Default redline shift beeper issues!
Well I got my shift beeper the other day, I wired it up going by the instructions and it worked perfect. Then 2 days later my step dad drove it to the store and said it was beeping at 4k. So I went outside and sure enough it was beeping at 4k. So I went in got my instructions and double checked everything. everything seemed to look just fine. I moved all the little things to the other setting then moved then back and it worked just find. Like it was suppose to.
Now today (the next day) I start up my car and its beeping at idle! wtf! I had to get to work and didnt have time to mess with it so I just unhooked the beeper so I wouldnt hear it beep and wne to work. Whats going on with it? I know its wired right, it worked perfectly the first day.
Old Jan 19, 2010 | 07:49 PM
josh7owens's Avatar
anyone
Old Jan 19, 2010 | 07:51 PM
CKit's Avatar
Those two statements don't necessarily follow.
Old Jan 19, 2010 | 08:16 PM
ans2k's Avatar
are you sure you are getting a good connection with all the wires?
Old Jan 19, 2010 | 08:22 PM
ans2k's Avatar
i remembered i connected the wires in the wrong spot, one spot over and it was working weird.
Old Jan 19, 2010 | 08:38 PM
josh7owens's Avatar
I used wire tappers to tap the wires, so I would think is a good conection. could it be the cold weather and maybe the car needs to warm up to operating temps to work right?
When it was messing up the first time i literally changed the settings then changed them back to what they were at to start with.
I would think that if I tapped the wrong wires it would of never worked right in the first place?
Old Jan 19, 2010 | 08:52 PM
ans2k's Avatar
no it wont "work" but it will beep. randomly
Old Jan 20, 2010 | 03:03 AM
josh7owens's Avatar
The first 2 days I had it hooked up it worked perfect and beeped at the set rpm (s). Since then though it's been really old out side and started beeping at wierd times. Ie- 4900 the first time, 1900 the second. I'll re-check all the wiring today and see if I can figure it out.
Old Jan 20, 2010 | 03:17 AM
CKit's Avatar
That's probably the best thing. T-taps can be adequate, but sometimes the connection is spotty. Soldering is really the way to go. I had a faulty connection in a different set of electronics give me a huge headache in troubleshooting. When having problems, triple check and then solder connections.
Old Jan 20, 2010 | 07:34 AM
josh7owens's Avatar
It would be a piain to solder them though becuase to hook it up you have to tap into a harness thats kind of a pain to get to. Its raining right now but I'll try to check it out later.
Greg W
Dec 11, 2008 10:29 AM
ecxphilzy
Sep 11, 2006 11:33 AM
Jason B
Jul 9, 2005 07:38 AM
lig
Apr 29, 2004 12:03 PM
