Removing OEM radiator shroud....
I will be installing an ASM radiator plate, and was wondering if most of you with aftermarket radiator plates remove the factory piece behind the bumper? I recall reading some threads a while back where you should remove the factory piece, because the new one does the same job. Just trying to verify.
Any help would be appreciated!!
lots of different opinions about that.
I'd say unless you have a snorkle - leave the OEM in - less turbulent air flow that way.
check this short thread
Comes down to whether you believe in Tuner Mags or Turbulence
Don't need a snorkel if your going with the AUt style one it will direct more air right at the filter. There is no need for the oem one at all. With a fan you can tell that it is directing air at the filter.
Originally Posted by chilicoke,Jul 21 2009, 01:47 PM
If you don't mind cutting your OEM air guide, I'd suggest trimming it to as close fit to the intake as possible and keep it on.
Originally Posted by slackfaster,Jul 21 2009, 01:52 PM
obviously believes more in Tuner Mags...
