Sponsored by: CARiD
S2k 2008
Old Jan 28, 2008 | 03:01 AM
boostp's Avatar
Default S2k 2008
just bought a new S2000. I would like to increase its power. Can I reach 280-290 HP on the engine with out using a Turbo or supercharge?
What parts do I need to reach this HP?
If i used a testpipe will i get the check engine sign?
Thank you
Old Jan 28, 2008 | 03:34 AM
HMFIC's Avatar
WEll pretty much bolt on's, depending how much money your gonna spend is prety much worthless compared to the price you pay for FI.
For example, purchasing bolt ons may not get you the power you want, and the money you spend for that, could get you very close to a turbo or SC. not sure how it would work on your car considering you have drive by wire,
And YES the testpipe will through the check engine light on. You have to get the ANTI-fouler plug and put that into the test pipe.
And one more thing. since i noticed your pretty new... and coming from experience being on this board. You might wanna use the search button first before posting quiestions on your VERY first day.
Welcome to S2KI!
Old Jan 28, 2008 | 04:13 AM
Enthralled's Avatar
get a Greddy kit. it'll get you to your power goal with minimal money spent. also, for the test pipe..get a T1R TP it comes with the CEL fix.
Old Jan 28, 2008 | 05:05 AM
deathsled's Avatar
Not without rebuilding the engine with a stroker kit that will cost you more than a turbo or supercharger
Old Jan 28, 2008 | 05:28 AM
boostp's Avatar
How many HP will the air intake,exhaust,testpipe and the headers will give all together on the whp and how much on the engine?
Will the A/F be lean?
Thank you
Old Jan 28, 2008 | 08:04 AM
Trent06's Avatar
roughly 20 hp give or take a few
Old Jan 28, 2008 | 08:12 AM
Amer's Avatar
Thank you
You can also add ITBs, TB, and VAFC probably good for an additional 15 whp.
Old Jan 28, 2008 | 10:12 AM
nearwater4me's Avatar
Welcome!
You'll learn a lot from this forum
I've been on this board about a year before actually purchasing one.
I knew all the weak/strong points of the S2000 before going to the dealer.
You'll get to know that the S2000 is pretty much maxed out from the factory.
You won't get noticeable HP gains from simple bolt-ons except for FI.
Hope this helps.
Enjoy!!
Dan
Old Jan 28, 2008 | 10:26 AM
EternalShadowAW's Avatar
well, j's 70rs, j's header, test pipe, and an asm/gruppe m intake or tsuchinoko can probably get you there. From there on, you swap to itb's, internal work, or stroker. Then you strip the sh!t out of it
Old Jan 28, 2008 | 10:55 AM
mrkjsn's Avatar
Go TC or SC and call it a day.
