Sponsored by: CARiD
seibon cf trunk
Old Sep 19, 2008 | 07:19 PM
sbrodacz's Avatar
Banned
That might be a good idea. What would an aftermarket latch do? Can't seem to find any.
Old Sep 19, 2008 | 07:27 PM
Rich@Empower's Avatar
here you go:
http://passwordjdm.com/Mugen-Tail-Gate-Fas...r-P814C396.aspx
Mugen tail-gate fasteners. Should work.
Baller status too
Old Sep 19, 2008 | 07:31 PM
sbrodacz's Avatar
Banned
it's out of stock i've found them somewhere else though. What would it do? Would it get rid of the factory latch?
Old Sep 19, 2008 | 11:25 PM
Shadow_S2K's Avatar
Former Sponsor
^ If you do go that route, you wouldn't need the stock trunk latch...but its going to be ugly.
When you get your trunk opened again try what I said above...all you got to do is LOOSEN the bolts that hold the trunk latch down...you can then move it around slightly...when you move it like down more then tighten the bolts to keep it that way. If that doesn't work I got another method.
Old Sep 20, 2008 | 08:43 AM
sbrodacz's Avatar
Banned
Well, I did get it to work I guess. I can't get the trunk open now. Once I get it open I just have to adj the hood it looks horrible with the gaps. As long as I can do that and keep it shut I won't go with the tail gate fasteners. But at least it's another option.
Old Sep 20, 2008 | 10:08 AM
Shadow_S2K's Avatar
Former Sponsor
Did you remove the trunk springs? If not...the only way to eliminate the gaps would be to remove the trunk springs...also if you want to prevent your trunk from warping over time. I believe if you remove the trunk springs, it will solve most of your problems.
Old Sep 20, 2008 | 10:34 AM
sbrodacz's Avatar
Banned
I have to remove one trunk spring? I see I can get the tool from hardtopgup. There is an horrible gap guess it doesn't really need to be aligned...
Old Sep 21, 2008 | 09:40 PM
Shadow_S2K's Avatar
Former Sponsor
You'll have to remove both...to be assured that your trunk will fit as good as it will fit and not warp over time.
Old Sep 22, 2008 | 04:47 AM
sbrodacz's Avatar
Banned
Ok thanks. Do you know anywhere to get the tool besides hardtopguy? $29.99 seems like a rip off!
Old Sep 22, 2008 | 06:56 PM
Shadow_S2K's Avatar
Former Sponsor
I would ask around your local area to see if you can barrow the tool, it takes like a minute to take the two springs off.
CrZy_Vick
May 9, 2011 07:57 PM
mrxjeffrey
Jul 26, 2008 05:49 PM
kaansahbaz
Nov 8, 2007 04:50 PM
ericshun
Oct 25, 2007 11:21 AM
chicagos2k
Feb 28, 2006 09:09 PM
