Sponsored by: CARiD
Side splitters
Old Feb 7, 2016 | 07:02 AM
torrbi's Avatar
Default Side splitters
Hey
I have made some searches of how others installed their splitters, but couldnt find much at all.
So here's how I did, in case someone else need some ideas
In this album you can see the pictures from start to completion
http://imgur.com/a/ZYMyn
Old Feb 7, 2016 | 05:17 PM
chubbys2k's Avatar
So u only have 1 screw on each side? Or did u add more?
Old Feb 8, 2016 | 12:11 AM
torrbi's Avatar
Oh I forgot to tell that i used 3 screwes like this in each hole that originally where there.
So there is 3 screwes on each side. I will add a scew up front to fasten it to the inner fender later.
Thinking about adding some 3m-double sided tape aswell..
Old Feb 8, 2016 | 10:05 AM
alSpeed2k's Avatar
RivNuts are also a good alternative.
Old Feb 9, 2016 | 09:57 AM
StockSH's Avatar
Finally! Thanks for your post as I always wanted to know how installation is done.
Are they called 'U nuts'? (Cage nuts?) Which type to use?
Old Feb 17, 2016 | 01:10 AM
Dman8's Avatar
thanks for posting install pics! I recently purchased rx7 side diffusers and will be installing it using your method.
Old Feb 19, 2016 | 01:07 AM
torrbi's Avatar
No problems. Glad to help! The ones I used is like 1 cm wide and like 2 cm long
No problems!
Even tho I used 3 screwes like this, they feel a little loose anyways, but that is thanks to the plastic material in my splitters. I maybe should have bought CF-splitters instead. But they make a fine look anyways!
I have ordered some strong 3M-tape to fasten them a little harder.
About the RivNuts they seem to do the job good too.
My U-clips does not scratch the paint since I bended them a little with a flat screwdriver. This way they don't bind as hard as they normally did, and they also became easier to attach.
I think my method is the cheapest way of doing this if you want to drill a small hole rather than a screw right through the chassis.
bumpinvtec
Nov 7, 2008 11:40 AM
Siver18
Mar 6, 2007 09:30 AM
WyattH
95
Jan 14, 2006 08:45 PM
mike_awkisbig
Jan 27, 2005 03:34 PM
s22k
Sep 9, 2002 07:54 PM
