Inner front fender install (Both L & R)
I am having the hardest time configuring which nuts and bolts (according to diagram) and how many of each to order for this install. If anyone has done this before or knows what this entails, advice would greatly be appreciated.
Webpage
Thanks
edit link
Webpage
Thanks
edit link
Hey Harry, hows everything? The diff is working out great by the way, thanks for all your help with that.
Back to subject at hand, the entire left side has nothing, but the right side has about 3/4's of the inner fender. I just want to redo both sides with all new everything. So I have a little bit of hardware, however, none of it will be used.
FYI the MY00/01 pictures suck. Use the MY02 or better picture for referance. To install everything you see on the picture, I think you need to buy the "Required Qty." of each part. But like #20, it is used on both side and in the center. But the common parts (like #20) are stocked at some dealers as it is common to many Hondas. Maybe this picture will help you better.
0piston
Nov 20, 2009 10:39 AM
06 S2K FTW
Sep 29, 2009 02:52 PM
