Sponsored by: CARiD
Soft top patch?
Old Sep 14, 2010 | 08:22 AM
S2kRally's Avatar
Default Soft top patch?
My top has developed a small wear spot, and a pinhole. Whats the best way to repair this to avoid a complete failure?
Old Sep 14, 2010 | 08:28 AM
240toS2k's Avatar
This is ghetto as hell but when my top was on order and I was waiting but needed to drive my car (I DD it), I used a torn old pair of jeans and glued it on the inside of the with fabric glue. I doubt that's a permanent solution though haha.
Old Sep 14, 2010 | 08:47 AM
S2kRally's Avatar
im looking for something permanent, to avoid replacing the top and preventing future wear.
Old Sep 14, 2010 | 09:13 AM
S2KPUDDYDAD's Avatar
Here is a thread I posted about a repair that is pretty easy and cheap too
I did replaced the top not long ago but, the repair was still fine and was as good as the day I did it.
https://www.s2ki.com/forums/index.php?showt...&#entry17836328
Old Sep 14, 2010 | 09:19 AM
Reckon's Avatar
I had some wear marks where the front bar slides (since my straps were loose) and I patched them with some black canvas strips glued on the inside. I replaced the straps so that they wouldn't rub like that anymore either. Patches work fine, even when wet (I didn't have a hole, more of a rub that was wearing down the material) and in the hot summer sun.
Old Sep 14, 2010 | 09:24 AM
s2k aok's Avatar
cheap and quick is black gorilla tape, extra sticky, not affected by heat and works...
Old Sep 14, 2010 | 09:49 AM
Mike21's Avatar
sew it closed with thread & needle(if it's big enough), then apply an iron-on patch on the inside. no need to fit an iron in there. bbq lighter with a credit card to smooth it out.
Old Sep 14, 2010 | 11:09 AM
S2kRally's Avatar
way to small to sew at this point, like i said its a pinhole, the whole wear spot is only about an inch long.
where could i buy some black canvas?
Old Sep 14, 2010 | 01:58 PM
ItsOver's Avatar
I went to a Tent Repair Store. They had a perfectly matching piece of material. $7 for the material and $5 for the glue. Well worth it and it's barely visible. GL!
Old Sep 14, 2010 | 04:30 PM
Toki's Avatar
Just cover the hole from the inside with black silicone adhesive sealant 16B Permatex. You can get it at any auto store for a few bucks. I used a toothpick to smooth it on. It has lasted 2 years with no wear.
