Soft Top WIND NOISE
Originally Posted by jWESTFOO' timestamp='1397764625' post='23117751
I've heard of people replacing the soft top strikers with hardtop strikers which seem to provide a tighter and closer hold. I don't know how effective they are, but it's something you could look into. A simple and cheap enough procedure too.
http://www.hardtopguy.com/store/prod...0&bestseller=Y
While installing my hardtop, after I added the hardtop strikers, I put the soft top back up and went for a drive. Absoultely a night and day difference. There wasn't much wind noise until 80mph+
A combination of two things fixed this in my old '00 and in my friends '01: The spacers under the latch bases, and greasing the of the rubber seals for the top (especially those up front)
Pick up some Shin-Etsu silicone grease (p/n: 08798-9013) from your local Honda dealer or online.
Clean all rubber seals with a rag, then thinly apply the Shin-Etsu
Usually best if you allow to sit overnight or at least for a few hours (it will actually soak into the porous rubber), then wipe off the excess (if any).
I know this subject has been beaten like a dead horse but what can I do to reduce this terrible wind noise. My soft top was replaced right before I bought the car, I am not sure if it an OEM top or Robbins. Either way, I would like to reduce the wind noise because it is absolutely brutal at highway speeds. I have already disconnected the catchers and added washers. This seemed to help minimally for a short amount of time. What other tricks are out there? Can you buy a better seal? Please help!
Grease the front seals (and probably good idea to do window seals too) and tight up the latches with hardtop strikes or I'm sure you can move it back a little so it pulls the top down more.
It's strange, if you put on a new top it should be really tight, almost too tight. When the fabric stretches out is when it gets all loose. When I installed my EZTop, it was really hard to latch but there was zero wind noise.
