Sponsored by: CARiD
Spark Plug Replacement
Old Oct 14, 2009 | 05:30 PM
MurderS2K's Avatar
Default Spark Plug Replacement
As the title says - need spark plugs.
Ive read to get the NGK IK22 or the IK24.
Whats the difference and what do you guys recommend?
Old Oct 14, 2009 | 05:53 PM
spectacle's Avatar
I recommend the OEM NGK's for a N/A car. If it isn't broke...
Old Oct 15, 2009 | 09:57 AM
Gruppe-S's Avatar
Banned
We recommend OEM NGK's IFR7G-11KS if you car is NA. We have them in stock. Give us a call when you're ready to order 949-457-1234 ext 2.
-Mike
Old Oct 15, 2009 | 03:29 PM
AlexS2200's Avatar
From: 13851 A Better Way #11D, Garden Grove, CA 92843
IK22 and IK24 are Denso not NGK. IK24 are good just more expensive. IK22 are OEM iridiums.
Old Oct 15, 2009 | 07:43 PM
MurderS2K's Avatar
what the size needed for the spark plug removal?
im going to have buy this damned tool
Old Oct 16, 2009 | 02:18 PM
JPWEraser's Avatar
NGK BKR7Es work perfectly too, even for boosted applications. They're less than $2 per plug and should be available at your local Auto Zone or Advance store.
Old Oct 16, 2009 | 02:23 PM
JPWEraser's Avatar
Just go to a tool store and ask for a spark plug socket. There are only 2 sizes that are commonly used and Hondas use the smaller one (I am unsure of the size but I will update this post when I get home from work and look at it).
Old Oct 16, 2009 | 06:35 PM
dammitjim's Avatar
5/8" is the size. Get a reasonably good one like a Craftsman. I've read about people rounding off spark plugs and it would seriously suck to have to deal with that. I can't imagine how they are doing it but it probably starts with cheap tools.
It's a good idea to tape the socket to the extension because they tend to get stuck on the plugs.
Old Oct 17, 2009 | 04:13 PM
iam7head's Avatar
stay away from denso plug, there's a few of those with broken tip and a broken motor because of it
cheap tool doesn't stripe off spark plug, people don't know how to use it properly does
Old Oct 19, 2009 | 05:39 AM
Gernby's Avatar
Former Sponsor
The difference between the IK22 and IK24 is the heat range. The IK22 is the stock heat range, which is hotter than the IK24. When I had my '02 S2000, I switched to the IK24 because it was colder, and would be less likely to cause pre-detonation. I believe this was part of the reason why my '02 consistantly had slightly more advanced timing curves than my buddy's '02 S2000 when we datalogged via OBDII. The only downside to the IK24 was that if I did several really short drives in a row, the IK24's would sometimes get a little bit fouled. Whenever that happened, it would miss a little bit until I cleaned them up with about 5 miles of spirrited driving. When I say short drives, I mean really short drives, like 1 mile to the beer store and back during an ice storm.
buzz944
Jan 24, 2016 03:56 PM
7rrivera7
Jan 30, 2015 06:23 AM
04BlackS2000
Dec 23, 2009 02:20 PM
HonCBRf2
Jun 28, 2008 12:42 PM
airgate
Feb 11, 2002 07:33 AM
