Spring Rates?
What are the stiffest spring rates for just springs and what are the average drops of each.
Swift-
Eibach-
Espelir-
Neuspeed-
Skunk-
Tein S-
Just want to see how they compare to coilover systems such as megan or buddy club and so on
I know the stock shocks for the s are quite good on rebound and if i can get close to the smae results with just springs for much less would rather do that.
thanks Jeremy
Swift-
Eibach-
Espelir-
Neuspeed-
Skunk-
Tein S-
thanks Jeremy
Swift-
Eibach-
Espelir-
Neuspeed-
Skunk-
Tein S-
thanks Jeremy
Swift-
Eibach-
Espelir-
Neuspeed-
Skunk-
Tein S-
thanks Jeremy
Tein Htech 268 330
Tein Stech 297 364 36/25
Espelir ASD 313 394
KG/MM SS 398 448
KG/MM R 298 448
Neuspeed 280 215
RSR down/ti2000 280 336
Spoon 263 383
Swift 258 241-336
Tanabe GF210 252 308
Tanabe NF210 224 280
Comptech 220 280
*double check and use at your own risk
go google on the drops, some spring is actually not bad. Mild drop with mild rate increase(eibach) is usable on the oem damper. the spring you want to avoid are low(aggressive drop) spring with stiff rate or worse, low spring with soft rate.
in short, if you going anything lower than 1 inch you'll run into 2 situation:
1) spring is stiff, you don't ride on bumpstop because of the spring constant but you over power the damper(under dampered)
2)spring is soft(remember it's proportional to the drop, etc), you run out of stroke and ride bumpstop everytime.
both are bad, the second one is worse.
oh yeah...a good percentage of spring is design on the ap1, the rear biased rate might not work well on the average "ap2" damper(since they are front biased)
with coilover you get a shortened(or adjustable) damper body, they give you alot of freedom with suspension travel, damper control and preload adjustable. is coilover always the golden answer for suspension quest? hell no, get what you need and budget accordingly. 90% of s2k driver are faster on the track with oem setup(personal opinion), because most of the people with 456 ways coilover can't tell the difference between the effect of too little preload from a slice of watermelon.
spring rate is just one thing about suspension, if you can't control(damper), use it(travel) or adjust it(preload, height, corner balance, etc), you are only getting so much done with just spring rate.
pershas it's time to someone to do a damper dyno on oem part.
S2000 CR OEM CR 392 342
Buddyclub Racing Spec 560 478
J's Racing SSK-S1-SH 1002 1002
JIC Magic FLT-TAR 672 560
KW V3 540 540
Moton Club Sport 650 600
Ohlins DFV 600 500
Spoon Full Space Adj 784 672
Tein MonoFlex 671 559
Apex'I N1 ExV 672 672
TEIN RA 672 672
TEIN CS 224 336
TEIN Flex 560 672
Stance GR 504 504
Buddyclub 10k 560 560
Zeal XS(street) 6k 336 336
Zeal 30 448 448
Spoon Showa Adj. 896 784
Bilstein PSS9 448 280
JIC FLT-A2 15 672 560
KW v3 504 504
ARK DT-P 504 504
K Sport Kontrol Pro 560 392
Megan Track 672 672
Megan Street 560 672
NEX SS NA 672 336
G4 24 728 403
D2 36 728 616
H&R NA 345 345
HKS HyperMax 392 280
T1R Bmax 4 672 672
i am including the rate of some of the most popular coilover for s2k
most of bell curve for street/weekend track set up is around 10-12 k front and 8-12k rear.
that's about 672 lb(at 12kg/mm), i doubt you can find something that harsh on spring(except going custom swift or eibach). come to look at it, your best bet for spring and damper combo is actually oem cr set up, you can get the whole shebang for under 1k otd
KW V3 540 540
Ohlins DFV 600 500
TEIN RA 672 672
TEIN CS 224 336
TEIN Flex 560 672
Stance GR 504 504
Zeal 30 448 448
KW v3 504 504
ARK DT-P 504 504
Megan Track 672 672
NEX SS NA 672 336
G4 24 728 403
D2 36 728 616
H&R NA 345 345
T1R Bmax 4 672 672
thanks a lot i no that coilovers are much better for a track application but im looking for something that is street worthy and track worthy.
The only reason i wonder about the spring rates is cause i know the stock dampening is quite good. and im afraid that going with a coilover setting i may just screw up what honda has done so well. im just looking for a stiffer spring to reduce wieght transfer in braking and cornering.
I have heard good things about the megan and buddy club for the cheaper spectrums of the coilover ladder.
[QUOTE=rotorman7,Feb 14 2009, 04:07 PM] thanks a lot i no that coilovers are much better for a track application but im looking for something that is street worthy and track worthy.
well the only reason i said megan is cause i have heard they are just the apexi ones that megan took over.
And by street worthy im not meaning a smooth ride that doesnt bother me. Im more worried about how it will fare on the track and in autocross.
i haven't even seen one single facts in any of the trend. bottom line: if you like apexi, trust apexi and want apexi quality then go for apexi.
having same spring rate is just one part of the whole picture, if you know what i am saying.
there's a debate like this about tein coilover, for my miata the spring rate for basic, flex and SS are the same and all the wiseful thinking people debate to death about they are the same basic stuff. now i just laugh
what is your budget btw? 12k is livable on the street for some people
bluemetals2k
Jan 24, 2011 03:29 PM
bluemetals2k
Jan 23, 2011 07:56 PM
