Steering Wheel install
ok i looked up the DIY on the sticky, but it doesnt have any pictures anymore, i have a couple of issues, first is the damn horn, i live in florida and people here dont know how to drive and i use it alot. if there is a picture of how to make it work again with step by step instructions that would be awsome. another is that pesky SRS light, i know i need a resistor but where do i put it and how many ohms to use??? last but not least my hub makes the wheel sit very close to my turn signal switch and wipers. what hub are u guys using and where can i get it.
Thanks Alot S2KI!!!
Thanks Alot S2KI!!!
srs resistor is a 2 ohm resistor: you can buy one from here: http://www.mynismo.com/products/?id=5239&rsku=0
its a female type.
the hub you got is more likely a short hub. if so I would recommend getting either a sparco spacer or get a quick release mechanism. if you hook up the system properly the horn should work. let me see if i can find the link for you...
its a female type.
samsam5886
Aug 15, 2013 08:33 AM
Freshjive
Mar 26, 2010 12:43 PM
