NRG Quick Release Hub
I'm planning to install a NRG quick release hub and probably get a Momo steering wheel with it. However, I have some questions regarding this set up.
1. Does anyone can refer me to any installation instruction? I searched but couldn't find anything on this topic.
2. I read that removing the OEM steering wheel will cause the SRS light to come on. Is there any way to fix this?
3. Does this mean I will lose the cruise control feature?
4. Is the NRG quick release adapter and a steering wheel all I need for this set up? Is there any other parts I need?
Thanks in advance for your input.
1. http://forums.s2kca.com/showthread.p...steering-wheel
You don't need the steering wheel puller unless you are a weakling lol, just wiggle it off.
2. Yes the light will go off, if you buy a new hub it will come with a resistor you stick in between the air bag wire harness
3. Yup, true s2k owners dont ever touch it anyways
4. Hub adapter (short) + quick release + steering wheel
Thanks for the information. You said I need hub adapter and quick release. I saw this item here, http://www.evasivemotorsports.com/mm...gory_Code=QR-6. Does this include both or I need to get a separate hub adapter?
Thanks!
death_blossom
Jul 26, 2009 02:19 AM
