Sponsored by: CARiD
taking off tint
Old Apr 17, 2008 | 06:20 PM
Skatethesea's Avatar
Default taking off tint
My friend is tryin to take his tint off his car cause it is illegal in virginia. Is there an easy way or a product that can speed up the process. He has spent three hours of his time getting nothing accomplished so far. HAHAHA. Thanks
Old Apr 17, 2008 | 06:25 PM
s2kAtTracks's Avatar
some heat and a razor blade and maybe some water
Old Apr 17, 2008 | 06:45 PM
NVMY4N's Avatar
window cleaner and a razor blade after the tint is off
heat for sure
Old Apr 17, 2008 | 06:49 PM
HotDamnitsDavid's Avatar
If he has glass coverage just break his windows. Problem solved LOL. J/K but like everyone said. Good luck with that.
Old Apr 18, 2008 | 07:44 PM
Timphan84's Avatar
soap + water + spray bottle + razor blades. The trick is to pull the tint off one corner and pull it off fast to the oppisite corner. You may get lucky and not get any glue on it. I used to tint windows.... After you pull off the tint if there is glue on it just spray and razor blade off.
Old Apr 18, 2008 | 08:12 PM
LostMotion's Avatar
Ammonia and heat.
Old Apr 19, 2008 | 11:54 AM
yellowlab's Avatar
Goo Gone cleaner. Majic American Products Inc. Bedford Heights Ohio.
I purchased this in canada for the removal of the glue after i took the oem tape off from around my windshield. i treated the rubber surfaces before using the googone and kept a supply of soapy water around to clean up the areas not requiring googone.use lots of product to get rid of the residue. it was my 1st time using the product and my windshield hasn't blown away yet. maybe others have warnings about the product that i haven't experienced yet. BTW, does anyone know what VTEC w/out the windshield feels like? will wrap-around sunglasses work until the insurance claim goes through?
www.googone.com, 800-321-6330.
Old Apr 19, 2008 | 12:59 PM
LostMotion's Avatar
Don't use goo gone on lexan for you mugen HT owners. Or at least test it first...
Old Apr 19, 2008 | 04:06 PM
jettfiery's Avatar
i've removed tint from a few cars and the best i've worked with so far is pretty much like wat everyone has said. Have a soapy water mixture, razor blade, and some heat. Comes off pretty easily.
Old Apr 19, 2008 | 06:07 PM
iam7head's Avatar
DO NOT USE RAZOR BLADE ON THE REAR DEFROSTER LINE!
now you have been warned, i removed tint a lots of time before.
this is what works best, do the pulling after the car been sat for hour under the sun(or you can use a heat gun), soap it with windex(the one with amonnia ) or what ever cheapest at walmart. if the temp is right you can pull about 70-80 percent of glue off along with the film. all the left over just soap it with windex(becareful with the interior tho), let it sit for 10 minture and take everything off with a blade.
for the rear window/defroster, use the extra fine steel wool, it works excellent.
gatorbait4me2000
South Florida
Feb 13, 2012 09:12 PM
ourru
Oct 25, 2011 02:56 PM
s2kJer
Apr 6, 2009 09:44 AM
Insert Name
Nov 25, 2004 05:06 PM
lostsol
Dec 9, 2002 09:06 AM
