Sponsored by: CARiD
Test Pipe Recommendations
Old Jun 28, 2011 | 01:51 PM
jelanier's Avatar
Default Test Pipe Recommendations
I am looking at the INV-HS00HS1TP2 Invidia that also claims CEL fix.
Anyone had experience with this product? Is there another one you would recommend ?
Jim
Old Jun 29, 2011 | 12:14 AM
liquid_helix136's Avatar
Ive got the Berk 63mm TP with CEL fix, been running it for about 30k miles and never seen a CEL. I think they make a 70mm now, but dont quote me on it. Ive also heard good things about the invidia test pipes, im sure it will work fine as theres not much to it really.
Old Jun 29, 2011 | 12:25 AM
toniotran's Avatar
a test pipe is nothing more than a straight metal pipe so as long as it has a bung for cel fix you should be fine and also make sure you get one that matches the diameter of the exhaust opening.
Old Jun 29, 2011 | 01:47 AM
s2cho's Avatar
i got the 70mm (cel fix) invdia tp on with the invidia n1 dual
no cel light and i would recomend it, less drone and vtec is smoother
Old Jun 29, 2011 | 02:07 AM
chViETnk's Avatar
ive had problems with invidias cel fix, it didnt work for my ap1 and i had to make my own
Old Jun 29, 2011 | 02:10 AM
boosted180sx's Avatar
I have a '03 and bought an invidia with a cel fix and haven't had a single problem with it.
but s2cho is right, it's just a metal pipe
Old Jun 29, 2011 | 05:55 AM
MasterForce's Avatar
i have the invidia 70mm with cel fix for my MY07. even thought it said CEL fix, i still got 2 anti foulers from autozone attached. no cel for 25k miles
Old Jun 29, 2011 | 06:24 AM
GoOn3's Avatar
just so you are aware.... the "CEL fix" is nothing more than a pipe that pulls the o2 sensor away from the test pipe so it see's less of the exhaust and therefore tricking the o2 sensor. You dont need to pay a ton extra for this "CEL fix" as you can do the same thing with two spark plug defoulers... drill out the top one that will be closest to the diode of the sesnor and then "bam" you have you "CEL fix" for nothing more than 5 bucks, a trip to your local auto parts store, and 10 min of your time!
Old Jun 29, 2011 | 07:12 AM
Reckon's Avatar
I've got the 70mm TP from Invidia. Mine has a CEL fix but they didn't ship it with the TP as they were out. It is supposed to be shipped when they have a supply (extender/angler that attaches to the bung). I have the CEL, but I just make sure to check it every few days to make sure it's just the secondary o2 sensor.
Old Jun 29, 2011 | 07:18 AM
JDMpearlwhyteZ's Avatar
Why waste time cutting into a test pipe and hacking it up, when you can buy one already made for it..
Test pipes aren't that expensive to warrant that IMO..
