S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
64mm ITB and 17" intake runners
Old 01-21-2017, 05:47 AM
  #31
Sylvain2000's Avatar
If your scoop is bolted to the hood.
Facing forward shinny day , rain comes , on bolt , rotate , re bolt , back on track
Old 01-21-2017, 07:13 AM
  #32
s2000ellier's Avatar
purchased a sti hood scoop replica to bolt on, will face the driver fender
Old 01-21-2017, 01:09 PM
  #33
s2000Junky's Avatar
That works, if you cant decide direction, split the difference I guess lol
  #34
haha it was purely a result of what scoops i could find on ebay that fit the dimensions of the hole i cut
Old 01-21-2017, 02:16 PM
  #35
Nice !!
That will have a "funny" Look.
Keep up !!
Old 01-22-2017, 07:54 AM
  #36
im sure it will look stupid but if its functional thats all i care about
Old 01-22-2017, 10:45 AM
  #37
rrounds's Avatar
Are you going to isolate the air horns from the under hood air/heat? If not, I can see hot under hood air having higher pressure than the inlet of the scoop at speed. In that case the air will move from the under hood to out of the scoop at speed.
Really like the project so far, function over form is always better on the track. Form over function is sometimes better for the car shows. I like the track.
ROD
Old 01-22-2017, 10:50 AM
  #38
yes i plan to put some sheet metal behind the rad and supported by the cross member that vents up out the hood. currently the car has a naca duct in the middle of the hood that i intend to remove.
once the scoop is in place im going to do some string tests and see how the air flows before i do the sheet metal
Old 01-23-2017, 12:45 PM
  #39
Mrsideways's Avatar
Originally Posted by s2000ellier
well spacers didn't work so...
not sure if i should do a front or rear ward facing scoop
Did you cut the hood with a butter knife?
Old 01-23-2017, 01:12 PM
  #40
4" angle grinder
Quick Reply: 64mm ITB and 17" intake runners
