Any clearance issues with COMETIC gasket and BC2 cams setup
Hi, any ideas if I face any clearance issues with the Cometic Headgasket if I go with Brian Crower Stage 2 NA Cams? Or are they good to go?
We did see some positive numbers with the BC Stage 2 cams! But of course that is with an EMS or FlashPro. Pretty Stable too.
We Dyno'd a TUNED S2000 with I/H/E on stock cams and BC Stage 2 Cams. You do see a bit more tq and hp thru out the band.. We are now waiting for the TODA Cam and see if that helps more.
OVERALL... GOOD BUY!
İ agree. Not toohigh numbers should be expected only with cams. We have seen 9-15whp gains (with Flashpro tuned) with BC2 cams and this is what you should expect if the car is healthy. Now we will try with headgasket setup and see what the gains are.
