S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Ap1 IAT sensor
Old May 11, 2014 | 06:35 PM
starchland's Avatar
Default Ap1 IAT sensor
Is there anyone who has relocated the ap1 intake air temp sensor to a location like it is on the ap2? Any experience? Any difference?
Old May 12, 2014 | 06:28 AM
Gernby's Avatar
Former Sponsor
Unless you have a standalone ECU, so that you can customize the fuel and ignition compensation tables for IAT, I think this would be a bad idea.
Old May 12, 2014 | 08:45 PM
06Estukay's Avatar
Jeff, quite a few turbo guys have done it with great success.
The problem with 06- cars is, the IAT sensor gets heat soaked. The reading that the sensor is providing does not necessarily correspond to the actual air entering the engine.
Anyhow, do some searching in the turbo section.
Old May 13, 2014 | 06:47 AM
yamahaSHO's Avatar
Relocating it to a position that does not get heat soaked would be beneficial, OEM or standalone. If you've ever tried to clean up fuel trims from a stock ECU (they're HIGH) and Greddy EMU, you'll see exactly how bad heat soaking the sensor affects the car. Nothing like waiting for your autoX run with the car trying to kill over at idle.
The OEM tables should already be set assuming no heat soak anyway.
Xeon
Dec 24, 2016 12:45 PM
F1 blue
Dec 21, 2016 11:17 PM
will010100
Nov 3, 2016 05:18 AM
Qiuness
Jun 24, 2010 02:00 AM
sach
Nov 9, 2005 09:22 PM
