Dyno Results - Stock vs Bolt On vs Tune (Karcepts)
Gotta tune, we don't have MAF sensors that can compensate for things that affect air flow, or fuel. Because our cars have MAP sensors, the computer relies on pre-programmed maps for various engine conditions, if you start changing things(bolt-ons) then the way the engine breathes changes, but the maps stay the same. When one tunes, they are essentially tweaking the engine maps to suit the new characteristics of the engine.
If we had combination MAF and MAP sensors tuning would be much easier, the ECM would compensate for any small changes in A/F ratio etc. You would only need to tweak fuel tables when you upgrade injectors, and play with ignition timing advance to control knock. With our cars, we have to tune everything just bolting on an intake and test pipe.
I've been looking at this package as well since I'm already in STR w/o a tune and it seems i'm at a huge disadvantage. But big issue is i'm in Oklahoma with no easy access to 93 octane. What's the impact to using 91 octane on the tune?
RAIN H8R
06-01-2017 05:03 PM
