Exhaust help?!
Exhaust help?!
So i recently swapped out my stock cat back with the invidia n1 dual. The drone doesnt bother me so much, but what i cant stand are the vibrations inside the car caused by the exhaust. Around 3,000 rpms the exhaust starts shaking just about anything that can rattle in my interior. I am wondering if either getting a new resonator or a test pipe would help with this issue?
No I went straight to the test pipe. Honestly you should ditch the invidia and get something else. While I didn't mind that exhaust while I had it when I switched to my Ti lite single I realized how crappy my invidia sounded and wished I had changed much sooner
I wouldn't say invidia is crappy....it is a good exhaust and is a top best rated by science of speed...it does drone a bit but i had minor vibrations not that bad....?? I would try the tp it kills the drone and should bring down the vibrations as well
You might try this
http://www.moroso.com/catalog/catego...?catcode=35054
Will it work on your vibrations? I don't know but it worked very well to get rid of drone in other cars I've had. And what is drone but a kind of vibration. I do know that the Moroso is cheaper($55 at Summit) than a new exhaust, so I would try it out before I spent more money on a whole new exhaust.
ROD
ROD
drone a bit? lol understatement of the year.
Thanks for the advice. I am actually pretty happy with the invidia, with the exception of the vibrations of course. I will prob just get a tp. I found someone in my area who will sell one to me cheap so seems like a done deal. Once i get this put on i will let you know if it helped. Thanks
The cheapest and probably best fix is to cut your test pipe and add a pre muffler exactly like this one
http://www.summitracing.com/parts/MPE-10416/
62 bux for the part + welding = done.
So i just put a testpipe on yesterday, and it did help with drone a little bit, but did nothing about the vibrations. :/
I read on another thread about some resonator that elimates all drone... maybe ill hed that way..
