S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
extrude hone oem intake manifold
Old 11-11-2012, 02:37 AM
lilboibounce's Avatar
Default extrude hone oem intake manifold
Alright, i want to know has anyone did the extrude hone to there oem intake manifold and got any gains out of it. And comparing the stock cfm to the hone cfm. Just wanted to know cause im trying to build a high response n/a s2k.
Old 11-11-2012, 07:19 AM
XxMerlinxX's Avatar
I just searched the board for "extrude" and the results do not look very promising. One member reported zero gains, though his S was supercharged. Don't know of anyone who was N/A that did it then dynoed to see what they picked up.
Old 11-11-2012, 11:45 PM
Yoohoo's Avatar
The stock manifold is very good the way it is. Maybe look into itb's if you have the funds?
Old 11-12-2012, 09:21 AM
Breaking Point's Avatar
The stock manifold is garbage man.I'd portmatch the runners to the head and hone the runners and the Plenum.
Old 11-12-2012, 11:08 AM
Banned
wadzii's Avatar
the biggest downfall of the stock manifold is the tiny plenum.. something extrude-honing simply can not fix.
Old 11-13-2012, 02:33 AM
You can open up the Plenum a few mm and in the na game every little thing counts.you should know that.you could try some of those bead hones to do the Plenum with so you don't have to cut and reweld it like most suggest.just be mindful of the amount of honing
Old 11-13-2012, 04:28 AM
Banned
wadzii's Avatar
Opening the Plenum a few mm wont help... it needs to have quite a bit of volume added. Not to mention the wall of the the Plenum is less than an inch from the opening to the runners which regardless of volume still restricts flow into the runners
staylor725
08-13-2019 03:38 AM
GrandMasterKhan
06-08-2009 10:40 AM
frofro24
11-05-2006 12:34 PM
PRS2K
05-17-2006 06:30 PM
Quick Reply: extrude hone oem intake manifold
