S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
f22 crank
Old Aug 25, 2014 | 05:32 PM
xeuz26's Avatar
Default f22 crank
I have a f22 crank and rods! what alse I need to stroker my f20c? what piston to use? f20 or ff22? any difrents? what will the compresion be like with the f20c piston! any help will be nice! thanks!
Old Aug 26, 2014 | 05:13 AM
Eriasu's Avatar
https://www.s2ki.com/s2000/topic/107...mation-please/
Old Aug 28, 2014 | 11:52 AM
xeuz26's Avatar
thanks you is there is any more info about it? im searching with no luck
Old Aug 31, 2014 | 11:19 AM
wadzii's Avatar
Banned
f22 and f20 pistons are interchangable. f22 pistons with f22 crank will get you 11:1 compression, f20 pistons with f22 crank will get you 12:1 compression
Old Aug 31, 2014 | 11:41 AM
Chance S2K's Avatar
If you're going all motor, you should definitely try using AP1 pistons with the AP2 Rods/Crank! 91/93 octane will still be usable, and if you get the car tuned you should see some pretty nice gains, especially in the mid-range.
Also, I just wanted to say OP has excellent choice in avatars
Old Sep 10, 2014 | 08:44 PM
xeuz26's Avatar
thanks u!!!
Old Sep 11, 2014 | 09:10 AM
Kermdaddy's Avatar
Fixed the title.
Old Sep 11, 2014 | 01:18 PM
dagle's Avatar
wadzii's the f'n man.
lol with his advice from a few years ago, my engine's still putting along nicely currently.
Old Sep 16, 2014 | 03:56 PM
xeuz26's Avatar
what whp can I look fowar to? I have 70mm throttle and manifold match,termal gasgets, asm 70mm exh, strait pipe 70mm, podio header, ct air filter modyfi stock box with snurkel and aem v2!
Old Sep 17, 2014 | 11:29 AM
Kermdaddy's Avatar
All depends on the tune and what kind of gas you use. Probably in the lower 200s i.e. 210-220.
geared
Jul 10, 2012 08:02 PM
bluemetals2k
43
Jul 3, 2010 10:32 AM
PeanutButter
Oct 6, 2007 01:45 PM
John_Z
Apr 10, 2007 11:59 PM
Team Hybrid
Nov 4, 2002 02:15 AM
