Help with AFR
Help with AFR
i just recently installed my AEM UEGO Wideband and took my car out for a spin to see what it's running at. Come to find out it bumps 14 AFR at vtec crossover and then settles at 13.8 afterwards. This is somewhat worrying as that is pretty lean under WOT. My current mods are K&N FIPK, 70mm test pipe, and invidia duals. So what kind of tuning method can i use that won't blow the bank. I drive a MY05 by the way. I know AEM EMS is the best but that is waaaaay out of my price range.
For the most part it runs pretty rich (normal for '00-'01 ECU) and then spikes real lean at 6k rpms. I didn't particularly like this so thats why I decided to use the F/IC to control my AFR. Plus I'm sure I can get some power by leaning out the mix where it goes into the low 12's.
The top graph above is the factory again, and the bottom one is the tuned AFR that I've achieved so far. Its a little rich throughout the whole thing but I wanted to have it in a safe range while doing all the tuning pulls. Now all I need to do is lean it out to around the 13.0 range. From what I've read you are going to want it no leaner than 13.5 during WOT. The best range seems to be 12.8-13.3 for power.
Former Sponsor
I'd be carefully using an FIC. They have proven to be really bad for the s2k. Especially AP1's. Some AP2's have had some success with them but AP1's tend to have hesitation issues using that to tune.
The yellow dots are the voltage during WOT. As you can see the voltage fluctuates within a range during open loop. It also doesn't change much throughout the rpm range. The darker dots are partial throttle signals. The stumbling is from the F/IC wanting to modify the fuel signal during closed loop because its receiving the desired voltage from the MAP sensor.
