Idle problem
Hi
I have a s2k from 2000 AP1 and the idle is only good in cool start and when you run normally the car does not have idle....
I run the car only once or two in one month but I cannot understand what the car have...
If you run the car in a long trip and now and then make some high rpms in the middle of the trip the idle will be ok , and you do not have more problems....
When you drive it next day the problem show up again....
Any idea/help for my problem?
Thanks
Thanks
Hi
Thanks
Thanks
Remove and clean the throttlebody and IACV. You probably have both of them clogged with dust, oil/grease, and etc. Cleaning those two items alone will fix majority of the idling issue. Because the car sits for a long period of time, you might have a weak battery. Another suggestion I could make is to use a fuel injector cleaner or Seafoam. By now, the injectors are probably fouled up with carbon buildup.
If I am reading this correct, the car runs fine at cold start and when you drive it hard. If that is so, I would suspect an o2 sensor going bad even if it doesnt have a code for it. The car doesnt use the o2 sensor in open loop (cold start) or at WOT. Maybe look into that.
SiDHEaD
Mar 14, 2014 05:01 AM
harrison1990
May 13, 2010 12:02 PM
