J's 2.0 or 2.2 question
like the title says i have some questions about the J's engine. anybody that has any knowledge about these engines post up.
Thanks
Blake
Thanks
Blake
well my biggest question is can they rev up quickly, can they rev high and how are those engines so good that they need a standalone ECU
abcvtec that is pretty good info thank you. when you mean cams do you mean gears or shafts?
Camshafts at least. Not sure about the gears. They need the custom ECUs because it's a custom build. With all of the work done there's no way a stock ECU could run it.
They don't require a standalone. It says it is recommended that you run the J's ECU. You could possibly get by with an e-manage ultimate depending on what else you have going on with the engine (i.e. ITBs, FI, etc.) -- although I don't see the point of running a regular intake setup on a $10k crate engine.
Come to think of it, I don't see the point of running a V-AFC on a $10k crate engine, either. If you were buying this engine, a true standalone (say a Hondata) with tune would still cost you about 25% of what you're spending on the engine. Common sense.
>>>>>> Estimate Charges <<<<<<
* J'S RACING F22C Complete Engine ASSY Spec-3 Engine Displacement: 2157cc Boar * Stroke: 87*90.7
Compression: 12.7
NEW engine cylinder head
NEW engine block
NEW engine head cover
Price: $11,880/-
* J'S RACING F22C Complete Engine Basic Menu All parts wash up Conrod and Piston full balance Valve sheet cut Valve measuring Metal measuring Port polishing
Price: $2280/-
* J'S RACING Complete Engine Option Set
J'S RACING SPL Oil Pan ASSY(NEW base)
J'S RACING SPL Head Cover(NEW base)
Price: $880/-
* J'S RACING SPL Valve Spring Set
Price: $650
Compression: 12.7
NEW engine block
Price: $11,880/-
Price: $2280/-
Price: $880/-
Price: $650
