k24 crank
k24 crank
Hi Guys !
I have a JDMs2k and i 'm willing to do the stroker kit by gary castillo , Gary states that you should use the OEM rods and pistons of an H22A engine , I have a ordered a brand new K24 crankshaft and a set of 900hp EAGLE CONNECTING RODS ! Should i have any problems in installing the eagle rods instead of the OEM ??
Thanks in advance !
:thumbup:
Thanks in advance !
:thumbup:
Here you go alot of information on the setup you are building.
http://www.superhonda.com/forum/f32/anyone...l-s2000-304198/
Here's some more info:
https://www.s2ki.com/forums/index.php?showtopic=538548
You wont have any problems installing the Eagle rods as long as you either had Eagle make them with the big end reduced by 2mm on each side, mill the rods down by 2mm on each side after you receive them, or mill the crankshaft's rod journals 4mm wider.
Originally Posted by ArchAngel2K,Oct 23 2008, 08:57 PM
i dont know this seems like a bad idea to me. shaving off metal from something that is suppose to be perfectly balanced. i just dont see it lasting long
yep, i agree with kial. doing a build like this, you're going to want to have EVERYTHING balanced anyway, so your motor doesn't vibrate apart. as long as you aren't subjecting this build to boost, it should be fine in terms of reliability. I bought everything new and still had all my stuff balanced and blueprinted.
