S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
k24 crank
Old 10-22-2008, 12:32 PM
spo001's Avatar
Default k24 crank
Hi Guys !
I have a JDMs2k and i 'm willing to do the stroker kit by gary castillo , Gary states that you should use the OEM rods and pistons of an H22A engine , I have a ordered a brand new K24 crankshaft and a set of 900hp EAGLE CONNECTING RODS ! Should i have any problems in installing the eagle rods instead of the OEM ??
Thanks in advance !
:thumbup:
Old 10-22-2008, 02:01 PM
learning03's Avatar
Here you go alot of information on the setup you are building.
http://www.superhonda.com/forum/f32/anyone...l-s2000-304198/
Old 10-22-2008, 03:51 PM
kial007's Avatar
Here's some more info:
https://www.s2ki.com/forums/index.php?showtopic=538548
You wont have any problems installing the Eagle rods as long as you either had Eagle make them with the big end reduced by 2mm on each side, mill the rods down by 2mm on each side after you receive them, or mill the crankshaft's rod journals 4mm wider.
Old 10-23-2008, 11:32 AM
spo001's Avatar
Hi Guys !
I appreciate a lot for your help !
Thanks again !
Will talk when my build up starts ..
Old 10-23-2008, 02:12 PM
S2Kage's Avatar
yeah im in the same boat, just need to buy the K24 crank
Old 10-23-2008, 08:39 PM
jdmfbpsi's Avatar
kial has one from a tsx... i bought one from a newer accord. if you get a hookup at honda, these are about $220 new. TSX cranks are $600+. STEAL!
Old 10-23-2008, 08:57 PM
ArchAngel2K's Avatar
i dont know this seems like a bad idea to me. shaving off metal from something that is suppose to be perfectly balanced. i just dont see it lasting long
Old 10-23-2008, 09:14 PM
S2Kage's Avatar
[QUOTE]
Old 10-24-2008, 04:53 AM
kial007's Avatar
You're really only shaving off an amount of material less than half the width of your pinky nail. 2mm on each side of the rod is pretty small. In terms of it being balanced, as long as you have a good machinist do the work the rods will come out square and true and balanced. My rods were cut on a lathe but they can also be cut on a vertical mill. This is still a good amount of work but it sounds like the rods are being altered a lot more than they are.
Old 10-24-2008, 09:09 PM
jdmfbpsi's Avatar
yep, i agree with kial. doing a build like this, you're going to want to have EVERYTHING balanced anyway, so your motor doesn't vibrate apart. as long as you aren't subjecting this build to boost, it should be fine in terms of reliability. I bought everything new and still had all my stuff balanced and blueprinted.
Quick Reply: k24 crank
