my ap1 back on the dyno with a 70 mm throttle body and a stepped intake
#151
i contacted Brian crower 2 month ago about the cam gears and they said it will be released very soon this year,also bisimoto said same about releasing camshaft.
would like to see comparison between the BC stage 2 and Skunk 2
#153
i would consider itb's but not toda. those are way too small. the size at the throttle body is 50mm. for a very efficient header and exhaust, 50mm would be too small for the throttle body size imo. if i were to get itb's it would be kinsler. they offer a wide range of sizes for the f20/22.
#154
Originally Posted by ipopvtec' timestamp='1334705893' post='21617631
b.r.i.a.n have you ever considered putting toda itbs on your car?
#155
http://www.k20a.org/forum/showthread.php?t=60947
on an f20 i think 52 or 54mm would work better especially with aftermarket cams. heck toda offers the same 50mm throttle bodies for the b-series motors and those heads don't flow as good as the f-series lol.
#156
Originally Posted by b.r.i.a.n.' timestamp='1334711522' post='21617931
[quote name='ipopvtec' timestamp='1334705893' post='21617631']
[/quote]
Hmm I was under the impression the toda unit was the best out there. I have heard people that went with jenevy and kinsler that if they could do it over again they would have 100% shelled out the extra money for the toda.
I think I'm going to stay at 2 liters through out my n/a build. As you go to 22 and 23 and 24 things get more complicated. I like the idea of a s2000 being a true 2000cc.
How come you havent pulled the trigger on the itbs yet?
#157
#158
My goals are similar, but I think I want to do ITBs first before internals because I would like to squeeze every ounce of reliability and mileage out of the stock engine before I touch the internals. Ive always wanted to build a motor from scratch- like in my basement starting from the oil pan up. That being said although I should have stayed stock, I already have intake header exhaust ecu etc. so I would like to work from the outside in.
I always had a feeling that when you open up the motor and play with the inside it just throws away reliability. Intake/exhaust and other supporting mods don't really affect it. I drive street and track so this is important to me. When I do build my own motor however these i/h/e mods can support it just ass well. I hope to have a 300whp n/a s2000 one day.. money permitting.
#159
Thats understandable... Do you think you will have more to gain if you get them later down the road?
#160
just a quick update. it has officially been over a year since my car first saw e85. it's still using the stock fuel lines and the stock fuel pump. the entire fuel system is stock minus the injectors. so those of you on the fence about running e85 on a stock fuel system because it's corrosive, don't worry about it lol. you're a-ok.
