S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
PLM Header Issues
Old Jun 7, 2010 | 08:33 AM
c.tran's Avatar
Default PLM Header Issues
I recently installed a PLM header into my 2004 S2000. The installation went well and the header is bolted to the engine tightly. At the moment, I am running open headers because I was also trying to install my Invidia 70mm TP as well, which would run to my stock exhaust. However, the PLM headers and Invidia TP came up short to the exhaust so I took the TP and exhaust off as a temporary fix.
When I run my car at anything other than idle, I can hear that the part of the headers where it converges into two pipes is vibrating against my transmission case. During installation, I saw that there was only about a 1/4 inch of space between the two.
Is this normal for those of you who have PLM headers? I am thinking that once i put on the rest of my exhaust system, it should stabilize the headers a bit more, which may stop them from vibrating against the tranny case. What do you guys think?
Old Jun 7, 2010 | 08:56 AM
sparrow's Avatar
I think you should complete the exhaust system and then report back.
Old Jun 7, 2010 | 09:00 AM
urBan_dK's Avatar
Agreed. Running an open header means it will have a much bigger potential to vibrate and bang into something. I can't remember how much clearance I had but haven't had this problem with my own PLM header.
Old Jun 7, 2010 | 12:19 PM
wisdom's Avatar
I don't have any fitment issues with my PLM header. Only problem I had was the collector, which I fixed with another donut gasket.
Old Jun 7, 2010 | 01:40 PM
Crackerballer's Avatar
Ummmm, open header, I imagine you would have some vibration problems. Also, how is your hearing?
Old Jun 7, 2010 | 02:11 PM
hypforlife32's Avatar
yeah bolt up ur testpipe and get the exhaust complete and youll be fine. i had alot of room around mine.
Old Jun 8, 2010 | 05:21 AM
c.tran's Avatar
thank you everyone for the feedback. yeah i figured it would help to complete the exhaust system, however my hks exhaust is on back order for a month so i suppose it will be a while before i report back again on this topic. thanks again!
andrew87890
Dec 29, 2013 11:38 AM
joefish1298
Jun 19, 2010 06:42 PM
myslow1
Mar 11, 2010 03:22 PM
STAIN
May 27, 2009 03:27 PM
s2kv
Feb 10, 2006 06:27 AM
