S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
s2000 apexi vafc
Old Jan 19, 2016 | 04:51 AM
s2kdrug's Avatar
Default s2000 apexi vafc
hello guys.i own an s2k 2002 model with HKS high power exaust system and an injen CAI.i bought an apexi vafc 1 and i was wondering if it would help me gain some power and if it's safe for my engine as well.thank you!!!
Old Jan 19, 2016 | 05:00 AM
RedCelica's Avatar
Moved to NA forum.
Old Jan 19, 2016 | 08:23 AM
Aurex's Avatar
https://www.s2ki.com/s2000/topic/110...t__p__23526879
Check the post linked above.
Also if you're set on the VAFC, get rid of the VAFC and pick up a NEO as it gives better control over vtec. The VAFC 1 will only allow vtec by RPM. The NEO will allow VTEC to be RPM and Throttle Position dependent.
Edit:
The tune will be as safe as you or your tuner makes it. You will need access to a wideband afr gauge.
Old Jan 19, 2016 | 10:08 AM
AP1Chief's Avatar
I got a safc2 for sale text me 7173986782
Old Jan 19, 2016 | 10:31 AM
s2000Junky's Avatar
Yep stick to the NEO, better vtec control, like stock. With the vafc 1&2 vtec will come on at a set rpm point, no matter what amount of throttle your giving it, which means you will be cruising in vtec at say 10% throttle on the freeway IF you want the rpm point set low enough to boost your mid range power. This means results in running overly rich and poor economy and throttle roll on engine response suffers. They are severely compromised in that regard. NEO is controlled by rpm AND throttle % like stock ECU. Mine is set to come on at 3600rpm and 30% throttle. This works the best overall for my modifications/ bolt ons. This just wouldn't be realistic with a pre NEO gen vafc.
Old Jan 20, 2016 | 01:50 AM
s2kdrug's Avatar
Thank you for your time guys! Apreciate it
Old Jan 20, 2016 | 07:51 AM
profit_child's Avatar
you can lower VTEC for AP1s its really the only thing that it does successfully... It gave me a nasty hiccup and i ended up taking it out.
Old Jan 22, 2016 | 04:43 PM
zeroptzero's Avatar
You will need to tune the fuel with a wideband or a dyno shop with a wideband. That is the only way to do it safely.
Gains depend on each individual vehicle and mods. But I love having a smooth vtec transition over the harsh oem set point. On my 02 I had it set at 5500 rpms and the transition is very smooth, so much better if you get vtec initiating in corners or long curves, and also better in wet conditions.
EsA2000
Apr 20, 2016 09:55 AM
rikhemi
Jan 14, 2008 02:28 PM
SPLNDID
Dec 26, 2007 07:25 AM
jdm j
San Diego S2000 Owners
Jul 28, 2007 01:01 PM
s2000coupe
Jul 19, 2002 06:36 AM
