should i dyno my stock S
Well you won't gain any power from a dyno. Dynos measure current power from your car not add any. If you want to mod then get a initial dyno which would be your baseline. You can use this to compare to future dynos post mods but only on the same dyno.
Get set up for an appointment to get your car tuned. When you take it, they will do a baseline dyno pull, then a tune with a final dyno pull. S2k's benefit from getting tuned and you can see increases throughout the rpm band. However, depending on your car's model year, you will need an ems (00-05) or a flashpro (06+).
What happened to the days where people on S2Ki had only positive information to give to someone. Not sure why so many people feel the need to make rhetorical or condescending comments for the new guest to S2Ki instead of pointing him in the right direction like ddess had done.
