S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
should i dyno my stock S
Old 11-10-2012, 11:56 AM
danielcrx's Avatar
Default should i dyno my stock S
Just wondering if I would gain or feel any power from dyno??? stock engine with stage 2 competition clutch kit.
Old 11-10-2012, 01:56 PM
ddess's Avatar
Well you won't gain any power from a dyno. Dynos measure current power from your car not add any. If you want to mod then get a initial dyno which would be your baseline. You can use this to compare to future dynos post mods but only on the same dyno.
Old 11-11-2012, 03:41 AM
ga s2000 man's Avatar
Nope no added power buddy
Old 11-11-2012, 11:18 AM
s2000maniac's Avatar
Old 11-11-2012, 12:27 PM
liquid_helix136's Avatar
What in the.. I just.
Old 11-11-2012, 04:40 PM
starchland's Avatar
should I wear deodorant...change my underwear (or at least flip/rotate)...etc...
Old 11-11-2012, 11:31 PM
Yoohoo's Avatar
You should definitely dyno your car. Plus add as many decals as possible, that should easily get you an extra 20hp. Good luck.
Old 11-12-2012, 04:11 AM
JUSTINTHECOASTIE's Avatar
Sure dyno it...
Old 11-12-2012, 05:22 AM
baZurk's Avatar
Get set up for an appointment to get your car tuned. When you take it, they will do a baseline dyno pull, then a tune with a final dyno pull. S2k's benefit from getting tuned and you can see increases throughout the rpm band. However, depending on your car's model year, you will need an ems (00-05) or a flashpro (06+).
Old 11-12-2012, 06:04 AM
billiardboy904's Avatar
What happened to the days where people on S2Ki had only positive information to give to someone. Not sure why so many people feel the need to make rhetorical or condescending comments for the new guest to S2Ki instead of pointing him in the right direction like ddess had done.
Quick Reply: should i dyno my stock S
